WYSIWYG Web Builder 6.1.1 update
*** Current version: WYSIWYG Web Builder 15.3.0 ***
Post by Pablo » Thu Aug 13, 2009 5:15 pm
This is a maintenance release. WYSIWYG Web Builder 6.1.1 fixes all known problems.
- Fixed: Object prefix issue with events on master pages.
- Fixed: Encoding issues with 'Single page protect' object.
- Fixed: Cloning page looses menubar button images.
- Fixed: z-index problem with PayPal options.
- Fixed: Replaced '100%' with actual size in YouTube object due to FireFox issues.
- Fixed: Impossible to select horizontal or vertical line on layer.
- Fixed: Removed line-height attribute from header styles.
How to update from previous 6.x versions?
1. Download version 6.1.1 here:
2. If you already have version 6.x you can install it over your previous version. Make sure you select the same folder!
http://www.wysiwygwebbuilder.com/wb6update.zip
