Extension Builder 2.0 released
*** Current version: WYSIWYG Web Builder 15.2.3 ***
Post by Pablo » Sat Sep 26, 2009 2:41 pm
New in Extension Builder 2.0:
- New feature: Added support for multiple preview browsers.
- New feature: Added option to specify the HTML document type for preview.
- New feature: Before <HTML> tag, Between <HEAD> tag and Between <BODY> tag are now have their own tabs for easier editing.
- New feature: Added 'Add folder' button on the Files configuration page, to quickly include complete folders.
- New feature: Added new edit field property type: multiple lines
- New feature: Added new edit field property type: rich text format (simple HTML)
- New feature: Added new edit field property type: html textbox
- New feature: Added 'Render HTML' option. Now you can specify HTML that will be used to render the object in the designer, independent from the actual output HTML.
The updated Extension Builder can be downloaded here:
http://www.wysiwygwebbuilder.com/extension_builder.html
(for WYSIWYG Web Builder 6 only!)
