WYSIWYG Web Builder 6.5.4 update
*** Now available: WYSIWYG Web Builder 14.3.2 ***
Post by Pablo » Mon Jan 18, 2010 4:50 pm
This is a maintenance release. WYSIWYG Web Builder 6.5.4 fixes all known problems.
- Fixed: Table cell alignment (justify not working).
- Fixed: Site HTML not saved.
- Fixed: Advanced button missing z-index.
- Fixed: Master frame missing styles.
- Fixed: Background alignment improvement for Firefox/Safari compatability.
- Fixed: Cloning login tools looses font.
- Improved: Added anti-alias text option to shape properties dialog.
- New feature: Added sub menu orientation property to menubar (bottom/upper left/right).
- New feature: Unicode version now also supports extensions!
How to update from previous 6.x versions?
1. Download version 6.5.4 here:
2. If you already have version 6.x you can install it over your previous version. Make sure you select the same folder!
http://www.wysiwygwebbuilder.com/wb6update.zip
