WYSIWYG Web Builder 7.2.1 update
Post by Pablo » Thu Oct 14, 2010 9:12 am
This is a maintenance release. WYSIWYG Web Builder 7.2.1 fixes all known problems and includes other minor improvements.
What's new in 7.2.1?
- Fixed: Buttonize does not work correct on low resolution images.
- Fixed: Problem with bullets in merged object.
- Fixed: Accordion and tab objects appear in Layer manager.
- Fixed: Form HTML preview displays code inside <div> tag.
- Fixed: Background of jQuery objects turns black, if the object is out of view while resizing.
- Improved: Added 'overflow:hidden' to marquee style (required for FireFox)
- Improved: Menubar now accepts <b>, <u> and <i> in item text.
- Improved: Image selection dialog now accepts folder names without using it as filename.
- Improved: Added 'Delete' and 'Select All' to context menu.
- Improved: Implemented workaround for Google Chrome table bug for better Menubar rendering.
- Improved: Added extra error handling to CAPTCHA.
How to update from previous 7.x versions?
1. Download version 7.2.1 here:
2. If you already have version 7.x you can install it over your previous version. Make sure you select the same folder!
http://www.wysiwygwebbuilder.com/wb7update.zip
