WYSIWYG Web Builder 4.2.1 now available!
Post by Pablo » Fri May 11, 2007 12:27 pm
WYSIWYG Web Builder 4.2.1 fixes all known problems:
- Fixed: Multiple Forms validation bug.
- Fixed: Color Eyedropper didn't work for text colors.
- Fixed: Text Menu items did not support &, >, < and " characters.
- Fixed: HTML output issues when using Windows 98
- Added: 'Shipping required' property to 'PayPal Add to cart'
How to update from previous 4.x versions?
1. Download version 4.2.1 here:
2. If you already have version 4.x you can install it over your previous version. Make sure you select the same folder!
http://www.wysiwygwebbuilder.com/wb4update.zip
