WYSIWYG Web Builder 8.0.2 update
*** Current version: WYSIWYG Web Builder 15.4.4 ***
Post by Pablo » Fri Dec 02, 2011 1:11 pm
WYSIWYG Web Builder 8.0.2 fixes all known problems and includes other improvements.
What's new in 8.0.2?
- Fixed: SlideShow 'scroll right' animation in News Feed Ticker.
- Fixed: Page count > 25 in Carousel causes crash.
- Fixed: YouTube autohide option works inverse.
- Fixed: Menu bar selects wrong font name if the font list is very long.
- Fixed: Added default line-height for HTML5 pages.
- Fixed: Added check for PHP magic quotes in CMS Admin script.
- Fixed: Button image selection in Menubar causes crash.
- Fixed: Layer on master page with overflow hidden causes crash.
- Fixed: Mega Menu's moveup/movedown buttons do not work for links.
- Fixed: Error reports generates size error for line object.
- Fixed: Problem with Arabic text in HTML object (Unicode version only).
- New feature: Add box-shadow to CAPTCHA
How to update from previous 8.x versions?
1. Download version 8.0.2 here:
2. If you already have version 8.x you can install it over your previous version. Make sure you select the same folder!
http://www.wysiwygwebbuilder.com/wb8update.zip
