Extension Builder 3.0 released
Post by Pablo » Fri Jan 20, 2012 9:24 am
New in Extension Builder 3.0:
- Fixed: Many minor bugs fixes
- Improved : Problem with Asset Management (filenames not being assigned correctly)
- New feature: Holding 'SHIFT' while clicking 'Add' in dataset properties will copy/clone the selected item.
- New feature: Added the ability to use different display values for options.
- New feature: Added 'Document ready script' to HTML tab. Can be used to initialize jquery scripts.
- New feature: Added 'publish to folder' to 'file' data type. Allows you to publish the specified file to a specific folder.
- New feature: Added the possibility to publish files to user specific target folder or fixed folder in DataSets.
- New feature: You can now use variables in any part of the filename eg: file$number$.xml or $name$.txt
- New feature: Added option to sort property categories/values (or disable it...)
- New feature: Added option to initially expand/collapse property categories.
Note that extensions created with this version will work in version 7.x and 8.x. However you will need a license for version WYSIWYG Web Builder 8 to use Extension Builder 3.
The updated Extension Builder can be downloaded here:
http://www.wysiwygwebbuilder.com/extension_builder.html
