WYSIWYG Web Builder 8.0.5 update
*** Now available: WYSIWYG Web Builder 14.3.2 ***
Post by Pablo » Mon Mar 05, 2012 10:17 am
WYSIWYG Web Builder 8.0.5 fixes all known problems.
What's new in 8.0.5?
- Fixed: Invalid title color in Photo Gallery when using jQuery Dialog.
- Fixed: Problem with nested layers in master page.
- Fixed: Carousel, jQuery Tab, Dialog, Accordion can now be used on a master frame.
How to update from previous 8.x versions?
1. Download version 8.0.5 here:
2. If you already have version 8.x you can install it over your previous version. Make sure you select the same folder!
http://www.wysiwygwebbuilder.com/wb8update.zip
