Extension Builder 4.1
*** Now available: WYSIWYG Web Builder 14.3 ***
Post by Pablo » Mon Sep 03, 2012 8:50 am
Extension Builder 4.1 introduces new features for WYSIWYG Web Builder 8.5 (available soon):
What's new in Extension Builder 4.1?
- New feature: Added 'disable debug' option in Extensions Manager.
- New feature: Added 'Enable events' option. Will add 'Events' property to properties. Use $EVENTS$ to add the events to your code!
- New feature: It's no longer necessary to create a separate .uwbx extension! Non-unicode extensions will be converted 'on the fly'.
- New feature: Rich text editor now supports links.
Note: These new features are only available in WYSIWYG Web Builder 8.5. However the extensions will also work in version 8.2, although the new options will be missing.
You can download the update here:
http://www.wysiwygwebbuilder.com/extbuilder.zip
(please read the updated documentation)
