WYSIWYG Web Builder 8.5 now available!
Post by Pablo » Sun Sep 30, 2012 5:27 pm
WYSIWYG Web Builder 8.5 is a major rebuild of the software with more than 50 new features and improvements.
A complete overview of the new features with screenshots is available here:
http://www.wysiwygwebbuilder.com/new_wb85.html
How to update from previous 8.x versions?
1. Download version 8.5 here:
2. If you already have version 8.x you can install it over your previous version. Make sure you select the same folder!
http://www.wysiwygwebbuilder.com/wb8update.zip
(build date: 10/12/2012)
