WYSIWYG Web Builder 8.5.2 update
*** Now available: WYSIWYG Web Builder 14.3.4 ***
Post by Pablo » Fri Nov 16, 2012 10:47 am
WYSIWYG Web Builder 8.5.2 fixes all known problems and includes other improvements.
What's new in 8.5.2?
- Fixed: Shared path problem in Flash Video Player.
- Fixed: YouTube player stuttering video caused by 'wmode=transparent'
- Fixed: Color picker 'More colors' picks the wrong color for text.
- Fixed: Parser error 'Script not closed' caused by quotes in script comments.
- Fixed: Zoom level not in sync with manual zoom value.
- Improved: styles with pseudo classes (:hover, :invalid etc) are now also included in HTML. A tutorial how to use this will be available soon...
- Improved: Updated twitter logos in Ready-to-use-Javascripts ('T' logo may no longer be used according to the Twitter Trademark and Content Display Policy).
How to update from previous 8.x versions?
2. If you already have version 8.x you can install it over your previous version. Make sure you select the same folder!
http://www.wysiwygwebbuilder.com/wb8update.zip (build date: Dec 7, 2012)
