CSS Sprite Image extension released.
Post by Pablo » Fri Nov 23, 2012 10:46 am
An image sprite is a collection of images put into a single image. Using image sprites will reduce the number of server requests and save bandwidth. Basically you combine all the images into one image and specify which part of this image will be visible by using the offset and width/height properties. Now you can use multiple instances of the CSS Sprite extension which all use the same image, each with different offset.
http://www.wysiwygwebbuilder.com/css_sprite.html
You can download the new extension through the Extension Manager (Menu->Tools->Extension Manager->Available).
Please read the help!
