WYSIWYG Web Builder 8.5.3 update
Post by Pablo » Mon Dec 17, 2012 7:50 am
WYSIWYG Web Builder 8.5.3 fixes all known problems.
What's new in 8.5.3?
- Fixed: Customizing format toolbar causes crash.
- Fixed: Check for updates fails on some systems.
How to update from previous 8.x versions?
2. If you already have version 8.x you can install it over your previous version. Make sure you select the same folder!
http://www.wysiwygwebbuilder.com/wb8update.zip (build date: Dec 16, 2012)
