WYSIWYG Web Builder 8.5.6 update
*** Now available: WYSIWYG Web Builder 14.3.4 ***
Post by Pablo » Wed Apr 03, 2013 8:42 am
WYSIWYG Web Builder 8.5.6 is a minor update.
What's new in 8.5.6?
- Fixed: Navigation bar size bug when the image is not found (for example if the project was moved to another computer).
- Fixed: Crash when using Ctrl+Z with Object Manager.
How to update from previous 8.x versions?
2. If you already have version 8.x you can install it over your previous version. Make sure you select the same folder!
http://www.wysiwygwebbuilder.com/wb8update.zip (build date: March 31, 2013)
