WYSIWYG Web Builder 8.5.7 update
*** Now available: WYSIWYG Web Builder 14.4 ***
Post by Pablo » Sat May 11, 2013 6:38 am
WYSIWYG Web Builder 8.5.7 is a minor update.
What's new in 8.5.7?
- Fixed: Links styles do not work in nested master pages.
- Fixed: Shape hover does not include title tag
- Fixed: Carousel, Tabs and Accordion may not display all objects when used on a master frame.
How to update from previous 8.x versions?
2. If you already have version 8.x you can install it over your previous version. Make sure you select the same folder!
http://www.wysiwygwebbuilder.com/wb8update.zip (build date: May 11, 2013)
