Extension Builder 4.2
Post by Pablo » Mon Jul 08, 2013 7:34 am
Extension Builder 4.2 has been updated for WYSIWYG Web Builder 9
What's new in Extension Builder 4.2?
- Added support for jQuery 1.9.1. Note that users can still select 1.7.2 in the page properties if necessary.
- Extensions created with this version will only work on WYSIWYG Web Builder 9 and newer.
- Remove colored backgrounds from tabs.
You can download the update here:
http://www.wysiwygwebbuilder.com/extbuilder.zip
If you want your extensions to be compatible with version 8 then please use the previous version:
http://www.wysiwygwebbuilder.com/extbuilder85.zip
