WYSIWYG Web Builder 9.0.5 update
*** Now available: WYSIWYG Web Builder 14.3.4 ***
Post by Pablo » Fri Aug 16, 2013 7:28 am
WYSIWYG Web Builder 9.0.5 fixes all known problems and includes other improvements based on user feedback.
What's new in 9.0.5?
- Fixed: 'Layer with gradient has border' issue.
- Fixed: Issue with Tab Menu Gradient Style not saved.
- Fixed: Menu Bar with border property set to zero not saved.
- Fixed: Full width floating layer bug.
- Fixed: Problem with 'target' trigger in transitions.
- Fixed: Added 'z-index' to non-modal jQuery Dialog.
How to update from previous 9.x versions?
2. If you already have version 9.x you can install it over your previous version. Make sure you select the same folder!
http://www.wysiwygwebbuilder.com/wb9update.zip (build date: August 16, 2013)
