WYSIWYG Web Builder 9.1.2 update
Post by Pablo » Mon Oct 21, 2013 3:27 pm
WYSIWYG Web Builder 9.1.2 fixes problems, adds new features and includes other improvements.
What's new in 9.1.2?
- Fixed: Problem with Pretty Photo lightbox and HTML5.
- New feature: Added new FTP engine option (Tools->Options->Publish & Preview). You can now switch between wininet or winsock.
Select winsock if you have issues with publishing in Windows 8.1.
How to update from previous 9.x versions?
2. If you already have version 9.x you can install it over your previous version. Make sure you select the same folder!
http://www.wysiwygwebbuilder.com/wb9update.zip (build date: October 26, 2013)
