WYSIWYG Web Builder 9.4.1 update
Post by Pablo » Fri Apr 11, 2014 5:06 pm
WYSIWYG Web Builder 9.4.1 fixes problems and includes other improvements.
What's new in 9.4.1?
- Fixed: Conflict with DBTS form processor. Removed hidden formid when built-in form processor is not enabled.
- Fixed: Rollover animation duration mix up.
- Fixed: Font preview in Text Art properties.
- Improved: Added extra height attribute for multiline items in SlideMenu.
- Improved: Added opacity support to Rollover Text fade effect in full mode.
How to update from previous 9.x versions?
2. If you already have version 9.x you can install it over your previous version. Make sure you select the same folder!
http://www.wysiwygwebbuilder.com/wb9update.zip (build date: April 11, 2014)
