Extension Builder 5.0
Post by Pablo » Mon Oct 13, 2014 11:25 am
What's new in Extension Builder 5.0?
- New feature: Added 'Designed for' option. Specifies whether the extension should be available in standard or mobile pages (or both).
- New feature: Added 'Set Extensions Folder' in tools menu. If this folder is set then Extension Builder will make a copy of the extension to this folder after it has been build.
You can download the update here:
http://www.wysiwygwebbuilder.com/extbuilder.zip
