WYSIWYG Web Builder 10.3.3 update!
Post by Pablo » Sat Mar 28, 2015 12:56 pm
WYSIWYG Web Builder 10.3.3 fixes all known problems, adds new features and includes other improvements.
What's new in 10.3.3?
- Improved: Added support for 'file upload' variables in rich text message of the form processor script.
- Improved: Border and shadow of panel layer.
- Improved: If the background mode of a master frame is set to 'transparent' then each page can now have its own background settings.
- Improved: Sticky Layer now supports relative sizing and alignment.
- Improved: Smarter handling of Google Fonts. For example WWB now understands the differences between 'Open Sans' and 'Open Sans Extrabold' and will generated the appropriate code.
- Improved: Added 'Non-responsive objects' option to View menu (previously only accessible through Shift+Ctrl+R). Enable this option to outline non-responsive objects.
- New feature: Added 'Render hidden objects' to View menu. This option may be useful to trace layout problems caused by hidden objects. Note that hidden objects cannot be edited.
- New feature: Added entry point for extensions to insert CSS and CSS for media queries/breakpoints (as alternative to 'Between <head> tags').
- New feature: Added 'Link' action to events. This makes it possible to create link from events. For example to add a link to a layer or trigger a link from a timer.
Extension Builder (5.2) has also been updated to support the new CSS (<style>) insert options. See the help of Extension Builder for more details.
How to update from previous 10.x versions?
2. If you already have version 10.x you can install it in the same location as the previous version.
This is yet another free update for all registered WWB10 users.
http://www.wysiwygwebbuilder.com/wb10update.zip (build date: March 29, 2015)
