WYSIWYG Web Builder 11.1.2 fixes known problems and includes other improvements.
What's new in 11.1.2?
- Improved: jQuery Button is now responsive.
- Improved: Better code for full width extensions in Layout grid with breakpoints.
- Improved: Issue with Shapes with hover in layout grid.
- Improved: Added 'fill-opacity' to Shapes with SVG output.
- Improved: Extension title can now be up to 50 characters long (instead of 25).
- Improved: Added border-sizing for full width Carousel with border.
- Improved: HTML 'rows' in Text Area has min value of 1.
- Improved: Added 'visibility' to inline frame in Layout Grid.
- Improved: 'Hide' command included in the Undo stack.
- Improved: XML processing now uses the heap if the stack is not large enough. This makes it possible (among other things) to have larger sitemaps.
- Improved: Asset Manager updates @font-face path when loading the project from a different folder.
- Improved: Panel plugin improvements (used by panel menu and layer).
- Fixed: jscookmenu reference should not be added for Responsive Menu in master page.
- Fixed: Issue with Article/Blog heading.
- Fixed: Layout grid issue when loading as page template.
- Fixed: Extra spacing between images in Photo Gallery.
How to update from previous 11.x versions?
2. If you already have version 11.x you can install it in the same location as the previous version.
http://www.wysiwygwebbuilder.com/wb11update.zip (build date: May 16, 2016)
WYSIWYG Web Builder 11.1.2 update!
