Navigation Extensions updated.
Post by Pablo » Fri Sep 23, 2016 2:49 pm
- Added support for email and file links to all extensions.
- Bootstrap Navigation Bar: Added support for transparent backgrounds in Bootstrap Navigation Bar.
- Bootstrap Navigation Bar: If a button only has one link, then the button will be used as the link instead of showing a drop down menu.
If you have previously purchased one or more of the navigation extensions then you can request the update here:
http://www.wysiwygwebbuilder.com/extension_update.html
More information about the navigation extensions:
http://wysiwygwebbuilder.com/forum/view ... =1&t=73800
