WYSIWYG Web Builder 5.04 now available!
*** Now available: WYSIWYG Web Builder 14.3 ***
Post by Pablo » Fri Feb 01, 2008 5:22 pm
This is a maintenance release. WYSIWYG Web Builder 5.04 fixes all known problems.
- Fixed: Search in bullets causes endless loop if string is not found.
- Fixed: SlideMenu can not be used on a master page.
- Fixed: PayPal custom image not saved.
- Improved: Increased extensions limit from 16 to 32
- Improved: Extended 'Web Builder extension API' for internal link support and some other enhancements (for future extensions).
- Improved: Folders in Slide Menu can now be moved up and down.
- Improved: 'Bookmark this page' script updated.
How to update from previous 5.x versions?
1. Download version 5.04 here:
2. If you already have version 5.x you can install it over your previous version. Make sure you select the same folder!
http://www.wysiwygwebbuilder.com/wb5update.zip
