WYSIWYG Web Builder 12.0.5 update
*** Current version: WYSIWYG Web Builder 15.0.7 ***
Post by Pablo » Wed May 24, 2017 4:58 pm
WYSIWYG Web Builder 12.0.5 fixes known problems and includes other improvements.
What's new in 12.0.5?
- Fixed: Lines which are part of a Page Footer but not within the viewport do affect the page size.
- Fixed: Removed redundant data-ride attribute from SlideShow->Carousel
- Fixed: Crash when adding box shadow to FontAwesome Icon.
- Fixed: Text object: Closing anchor tag should be before the end of heading tag.
- Fixed: Crash when using undo with SVG extension.
- New feature (experimental): Added new 'Full Width' options for third party extensions: "width: 100%, height: auto" and "width: 100%, height: fixed" (note that these only apply to 'use div' extensions!)
How to update from previous 12.x versions?
2. If you already have version 12.x you can install it in the same location as the previous version.
http://www.wysiwygwebbuilder.com/wb12update.zip (build date: May 24, 2017)
