WYSIWYG Web Builder 12.1.1 update
*** Current version: WYSIWYG Web Builder 19.2.0 ***
WYSIWYG Web Builder 12.1.1 fixes known problems and includes other improvements.
What's new in 12.1.1?
- Improved: Carousel should not display background overlay option.
- Improved: Bulleted list height calculation in layout grids.
- Improved: Added 'transparent' option to text shadow property in jQuery Mobile Themes. This makes it possible to disable the text shadow for text.
- Fixed: Bulleted list should not be a drop container.
- Fixed: Open Graph Meta Tag og:url is missing.
- Fixed: 'Rotate' button is hidden.
How to update from previous 12.x versions?
2. If you already have version 12.x you can install it in the same location as the previous version.
http://www.wysiwygwebbuilder.com/wb12update.zip (build date: July 17, 2017)
