WYSIWYG Web Builder 14.0.1 update
Post by Pablo » Fri May 11, 2018 11:55 am
WYSIWYG Web Builder 14.0.1 fixes known problems and includes other improvements.
What's new in 14.0.1?
- Fixed: Missing 'width' in Bulleted List.
- Fixed: Rendering issue with zoomed workspace.
- Fixed: Conflict with external scripts and schema.org JSON
- Fixed: 'Find not found' error with some extensions.
- Fixed: Implemented workaround for Layout grids with maximum width, so they use 'old' behavior automatically. See the help for more details.
- Fixed: Login Admin produces demo code:(
- Fixed: Single character glyphs in Icon Fonts do not render.
- Fixed: Issue with user roles in Login Admin
- Improved: SVG output for Material Icons.
- Improved: During the setup, blocks/icons will no longer be installed in the user's document folder. Because when the setup is executed with different credentials, the files ended up in the wrong folder.
- Improved: Added support for Unicode files names in zip backup.
- Improved: class property does not disable object's CSS output.
- New feature: Added 'trigger change' action to Form Conditions. When you set the value of another object via conditions, then browsers will not trigger a change event for that object. This action adds the ability to force a change event, which may be useful if the value is used in other conditions..
New tutorials
How to integrate Cushy CMS?
http://wysiwygwebbuilder.com/cushycms.html
How to integrate Surreal CMS?
http://wysiwygwebbuilder.com/surrealcms.html
How to update from previous 14.x versions?
2. If you already have version 14.x you can install it in the same location as the previous version.
http://www.wysiwygwebbuilder.com/wb14update.zip
