WYSIWYG Web Builder 14.0.5 update
Post by Pablo » Fri Jun 22, 2018 11:45 am
WYSIWYG Web Builder 14.0.5 fixes known problems and includes other improvements.
What's new in 14.0.5?
- Fixed: Font sizes in extension datasets are not converted to pixels.
- Fixed: Issue with edit profile/avatar and minified HTML.
- Fixed: Structured Data Object Adds Scrollbar
- Fixed: Cannot insert new item in empty card item list.
- Improved: Added confirmation box to 'Reset toolbox'.
- Improved: Reversed the order of @font-face fonts (woff2, woff, tff, svg, eot)
- Improved: Sticky Layer now uses CSS instead of JavaScript when delay is set to 0
- Improved: Added 'mute=1' to YouTube and Vimeo background video.
- Improved: Added latitude/longitude properties to 'Google Maps with Info' script.
How to update from previous 14.x versions?
2. If you already have version 14.x you can install it in the same location as the previous version.
http://www.wysiwygwebbuilder.com/wb14update.zip
