WYSIWYG Web Builder 14.1.1 update
Post by Pablo » Tue Aug 21, 2018 9:23 am
WYSIWYG Web Builder 14.1.1 fixes known problems and includes other improvements.
What's new in 14.1.1?
- Fixed: Issue with Card alignment in breakpoints.
- Fixed: CSS menu border hover color.
- Fixed: Issue with progress bar percentages in floating layout.
- Fixed: Issue with empty Marquee and HTML formatting tools.
- Fixed: Label 'for' attribute is empty when used with master frames/pages.
- Improved: Hidden Inline Frame now uses 'display:none' instead of 'visibility:hidden' in Layout Grids.
How to update from previous 14.x versions?
2. If you already have version 14.x you can install it in the same location as the previous version.
http://www.wysiwygwebbuilder.com/wb14update.zip
