WYSIWYG Web Builder 14.2 update!
Post by Pablo » Tue Oct 02, 2018 7:55 am
WYSIWYG Web Builder 14.2 is a major update. This version fixes known problems, adds new features and other improvements.
What's new in 14.2?
- Fixed: Switching from Master Page to Master frame crashes program when the page is not active.
- Fixed: Issue with Panel Menu hamburger image in breakpoints.
- Fixed: Visibility issue with images in flexgrid and breakpoints.
- Fixed: Login Name does not apply background alpha value.
- Fixed: Panel Layer overlay hidden in breakpoints.
- Improved: Added justify-content to Layout Grid when using flexbox/fixed height.
- Improved: It is now possible to use multipe (form) conditions with the same value for "equal to (choice)/not equal to (choice)", so you can trigger different actions for the same value.
- Improved: Now includes PHP Mailer 6.0.5 (upgraded from 5.2.26) with many improvements: https://github.com/PHPMailer/PHPMailer/ ... angelog.md
- Improved: Implemented workaround for 'Failed to open document' error when extensions are missing.
- Improved: Projects with extensions can now be opened in the TRIAL version. Extensions will not be functional in demo mode but the application will no longer generate an error (or crash).
- Improved: Form's encoding type defaults to 'multipart/form-data'.
- Improved: Newly added objects in layers will automatically be moved into the viewport if they are not visible in breakpoints (experimental).
Single Page Protect
- Improved: Redesigned 'Single Page Protect' so it's more mobile friendly.
- New feature: Added extra styling options to 'Single Page Protect': colors, padding, border-radius, button and editbox styling etc.
Quick 'n Easy Web Builder 6.x export
- New feature: Added support for export to Quick 'n Easy Web Builder 6.x format.
Variables
- New feature: Added 3 new built-in variables: $PAGE_NAME$, $PAGE_TITLE$ andf $PAGE_FILENAME$. These variables can be used anywhere in the page and will be replaced by their actual values when the page is published.
List View
- New feature: Added alignment property to List View. The alignment is responsive.
Slide Menu
- New feature: Added alignment property to Slide Menu. The alignment is responsive.
Cards
- New feature: Added the ability to add YouTube/Vimeo videos to Cards.
- New feature: Added 'Icon library' option to Card, this makes it possible to use custom fonts (in addition to Font Awesome).
Panel Menu
- New feature: Added the ability to set different colors for the button and menu items in Panel Menu.
Navigation
- New feature: Responsive Menu, Breadcrumb, Tabs, Overlay Menu and Panel Menu now support custom icon fonts (in addition to Font Awesome and Material Icons).
How to update from previous 14.x versions?
2. If you already have version 14.x you can install it in the same location as the previous version.
http://www.wysiwygwebbuilder.com/wb14update.zip
