WYSIWYG Web Builder 14.2.2 update
Post by Pablo » Mon Nov 12, 2018 4:39 pm
WYSIWYG Web Builder 14.2.2 fixes known problems and includes other improvements.
What's new in 14.2.2?
- Fixed: Incorrect warning in Error Reports for master page with events.
- Improved: Alignment of small shapes.
- Improved: Form now removes leading and trailing spaces from email address to prevent validation error.
- Improved: Added z-index to flex container with image overlay.
- Improved: Select below/above now include objects with 0 pixel offset (instead of 1).
- Improved: (drawing) Line offset is now longer affected by default page font-size.
- Improved: Margin issue in floating layer in workspace.
How to update from previous 14.x versions?
2. If you already have version 14.x you can install it in the same location as the previous version.
http://www.wysiwygwebbuilder.com/wb14update.zip
