WYSIWYG Web Builder 14.3.4 update
*** Current version: WYSIWYG Web Builder 15.4.4 ***
Post by Pablo » Fri Apr 26, 2019 5:58 pm
WYSIWYG Web Builder 14.3.4 fixes known problems and includes other improvements.
What's new in 14.3.4?
- Fixed: Incorrect flexbox offset calculation for multi-line rows.
- Fixed: Crash when updating master page in multi-page properties.
- Fixed: Crash when modifying font in styles.
- Improved: Ready-to-use-JavaScript preview is now DPI aware.
- Improved: Spell checker via F7 makes sure first text object gets focus.
- Improved: Added style support to Flex Container form.
- Improved: Logout button full width behavior in layout grids with breakpoints.
- Improved: 'fixed' and 'cover' options in Page background image now work in Safari Mobile (iPad/iPhone). Enable 'Safari background fix' in the page properties.
How to update from previous 14.x versions?
2. If you already have version 14.x you can install it in the same location as the previous version.
32bit: http://www.wysiwygwebbuilder.com/wb14update.zip
64bit: http://www.wysiwygwebbuilder.com/wb14x64update.zip
