CSV CRUD extension released (paid).
*** The current version is: WYSIWYG Web Builder 20.2.2 ***
CSV CRUD is a CSV editor for WYSIWYG Web Builder that will allow you to create, read, update and delete records of a CSV file on your website. The acronym CRUD stands for Create, Read, Update and Delete.
Features
• Create, read, update and delete csv records
• built-in search
• sort columns
• pagination (number of items per page)
• bootstrap 4 look and feel
• specify required input fields
• specify maximum length of input fields
• configure which fields to display in the listview
• input types: editbox, textarea, combobox (with options) and checkbox
• configurable text labels (language)
• many style options: colors, padding, font, bordered table etc.
http://www.wysiwygwebbuilder.com/csvcrud.html
The demo version can be downloaded via the Extension Manager (Menu->Tools->Extension Manager->Online Gallery->Forms).
Purchase for $7.95
https://secure.2checkout.com/order/chec ... T=1&CARD=1
