Important information about the usage of templates/images
Post by Pablo » Fri Aug 18, 2006 9:51 am
Here is some important information about the usage of templates and images.
When using templates from this website, the forum or any other location, it's important to understand that these template may contain copyrighted images.
In most cases the images are intended for clarity and for purposes presentation only.
If you plan to use a template as the basis of your website then you should replace all images of people, objects, animals etc with images that you have a license for!
Using unauthorized images may result in copyright claims from the copyright owner!
WARNING:
Image services are very active in finding websites that infringement the copyrights of their images, so please be better safe than sorry!
Just because these templates are on our website does not mean that we own the copyrights, most templates were created by other users and there is no way for us to verify whether the used images are officially licensed. So we have placed the templates on the website in good faith. But just to be sure you should never used the included images on a live website!!!
In no event shall Pablo Software Solutions or its suppliers be liable for any damages (including, without limitation, damages for loss of data or profit, or due to business interruption,) arising out of the use or inability to use the materials on Pablo Software Solution's Internet site, even if Pablo Software Solutions authorized representative has been notified orally or in writing of the possibility of such damage.
Of course we will remove any copyrighted material immediately when we find out something is wrong.
By using templates from http://www.wysiwygwebbuilder.com you acknowledge that you have read, understand and agree to the term of this agreement.
IF YOU DO NOT AGREE TO THESE TERMS, DO NOT USE THE TEMPLATES IN ANY WAY, AND PROMPTLY DELETE ANY COPIES OF THE TEMPLATES IN YOUR POSSESSION.
Re: Important information about the usage of templates/image
Post by Pablo » Sun Oct 27, 2013 12:38 pm
Update:
We strongly recommend to verify whether you have used templates that were created by v84x4, drkalchev, GOEMO and others.
We have reason to believe that some of templates may have contained copyrighted material!
The doubtful templates have been removed several weeks ago, but it's good to check and make sure you have replaced the images with your own images.
Here's a tool that may help you find the license of an image:
http://www.picscout.com/solutions/search/
