Installation issues? Please read this topic!
Post by Pablo » Tue Feb 27, 2007 5:43 pm
If your download is corrupted, the most likely problem is that your download failed to complete or was truncated for some reason.
The files on our server are 100% valid, so if your download failed follow these steps:
1) Remove the corrupted file from your computer
2) Clear your browser cache or remove the invalid download from your browser's cache manually.
3) Restart your browser
4) Disable any download manager you may have installed, this may corrupt the zip file.
5) Download the file again.
If the setup asks for disc #1 (or something like that), then your download is corrupt or your temporary windows folder is full.
Use the Windows Disk Cleanup utility to make some free space.
Another great utility to fix system problems is CCleaner: https://www.piriform.com/CCLEANER
To download the latest version please go to:
Or use this alternative location:
http://www.wwb-support.com/downloads/webbuilder10.zip
Post by Pablo » Sun Aug 29, 2010 6:51 am
Post by Pablo » Sun Feb 01, 2015 4:45 pm
TIPS:
- Do not launch the setup directly from the zip file[/b], but extract it first to folder somewhere on your local disk.
- Make sure your virus scanner does not block the setup.
