Help my pages does not look as intended!
Post by Pablo » Fri Feb 22, 2013 1:49 pm
Do you have the latest version of the software?
Make sure you are running the latest version, because if there are any known problems then we usually fixed them a.s.a.p.
Perhaps you have added invalid code or placed it in the wrong part of the page?
- Remove the code or make sure it's 100% valid and does cause conflicts with other parts of objects on the page.
Related tutorial: http://www.wysiwygwebbuilder.com/add_html.html
Did you use any unofficial extensions?
Some unofficial extensions may cause conflicts with standard elements. Try to remove the extension(s) and then republish the page.
Did you optimize your text for different browsers?
Related FAQ: viewtopic.php?f=10&t=34318
Did you use invalid files names?
Related FAQ: viewtopic.php?f=10&t=131
Did you use objects that require PHP, but not set the file extension to 'PHP' in page properties?
Related FAQ: viewtopic.php?f=10&t=36493
Did you use fonts that are not web safe?
Please read 'web safe fonts' in the help for more details.
Related topics:
