Re designed my site amibrokerlivedata with wysiwyg12
You can use this section of the forum to show your website created with WYSIWYG Web Builder to other users.
pankaj.arya
Post by pankaj.arya » Mon Jun 26, 2017 5:43 am
Hi all
i have re designed my website http://amibrokerlivedata.com using wyswyg 12
do check it on mobile and give feedback
Cheers
WYSWYG 12 Rocks
I love wysiwygwebbuilder
alexmasss
Re: Re designed my site amibrokerlivedata with wysiwyg12
Post by alexmasss » Mon Jun 26, 2017 6:28 am
You are combining colors that are not suitable. Consider to change the color scheme. The distance between the rows is not the same. Leave a space on Contact us page, you have written Contactus. Make the footer smaller. Use another menu on the top.
pankaj.arya
Post by pankaj.arya » Mon Jun 26, 2017 6:31 am
If i use another menu at top
do i have to use breakpoints ?
alexmasss
Post by alexmasss » Mon Jun 26, 2017 6:38 am
Usually I use 2 or 3 breakpoints because the design looks better. However it depends of what menu you want to use and how do you want it to be displayed.
pankaj.arya
Post by pankaj.arya » Mon Jun 26, 2017 6:48 am
Hey Alexmass
do you think this site, http://www.wysiwygwebbuilder.com/forum/ ... 17&t=77266 is made in wysiwyg 12 ?
If so , how can i achieve same Top menu like him
i have tried blocks but Text and Menu comes in Different like this http://amibrokerlivedata.com/test2/temp/Test.png
alexmasss
Post by alexmasss » Mon Jun 26, 2017 2:51 pm
You asked how the top menu was made on the website ***url removed***. I have done something similar in the past and I made for you a simple demo. This require a commercial extension called RZ-align-object available from ***url removed*** If you want to open/edit the demo you will have to purchase a license for this extension. Here you can download the wbs project https://yadi.sk/d/767MdDgG3KTv7A (without the extension) and an online demo is available here *** url no promoting your own website in anothers thread.***
Post by BaconFries » Mon Jun 26, 2017 3:12 pm
Please see Pablo's answer to your question at the following to what is used.
https://www.wysiwygwebbuilder.com/forum ... 40#p386940
EduardoVolpi
Post by EduardoVolpi » Thu Jun 29, 2017 12:05 am
Hey Alexmass
Hi pankaj,
Yes, the site (*** EduardoVolpi no promoting your own site in anothers thread*** ) was made in wysiwyg 12, only. The only extension used was the Expandable Panel Menu
me.prosenjeet
Post by me.prosenjeet » Thu Jun 29, 2017 3:06 am
Can you tell how did you do the notification part? A popup came saying this website wants to send you notifications.
pankaj.arya
Post by pankaj.arya » Thu Jun 29, 2017 3:08 am
Currently i am using https://www.foxpush.com they allow 50,000 free users then Paid $49 pm
