Lightbox Issue
barryrodgers
Lightbox Issue
Post by barryrodgers » Wed Feb 07, 2018 4:41 pm
Hi
I made a page with a page opening in a lightbox when a CSS3 button was clicked and it worked fine.
I then did the exact same set up in a different page and the lightbox will not display (in preview or when uploaded)
Here is a video showing the issue https://cl.ly/1O2v3a2S2k3c
Barry
Re: Lightbox Issue
Post by Pablo » Wed Feb 07, 2018 4:59 pm
Please include the URL of the page or a link to your project file so I can see what you have done.
barryrodgers
Re: Lightbox Issue
Post by barryrodgers » Thu Feb 08, 2018 7:38 am
I uploaded the site here: http://brryr.im/newtest/
The lightbox page is http://brryr.im/newtest/page1.html
How can I send the project file information in a PM?
Re: Lightbox Issue
Post by Pablo » Thu Feb 08, 2018 7:57 am
The following files are missing on the server:
fancybox/jquery.easing-1.3.pack.js
fancybox/jquery.fancybox-1.3.4.css
fancybox/jquery.fancybox-1.3.4.pack.js
fancybox/jquery.mousewheel-3.0.4.pack.js
Please make sure you have uploaded/published all files.
To share your project:
- remove all non-relevant content from the project
- upload the project to your website or another public server
- share the link
barryrodgers
Re: Lightbox Issue
Post by barryrodgers » Thu Feb 08, 2018 9:42 am
Thanks.
I did upload all files created when I saved as HTML. Those folders/files were not created.
Re: Lightbox Issue
Post by Pablo » Thu Feb 08, 2018 9:58 am
When you save the page as HTML only the HTML file will be saved.
You will need to publish the page to generate all files.
http://wysiwygwebbuilder.com/publish.html
barryrodgers
Re: Lightbox Issue
Post by barryrodgers » Thu Feb 08, 2018 10:11 am
Thanks.
In the last project (which also had a page with a CSS3 button opening another page in a lightbox) I just saved as html and those files were created within a folder named "fancybox".
I did try using the publishing function just now and it produces the same results ( see this video https://cl.ly/3F0G3u15081m )
Barry
Re: Lightbox Issue
Post by Pablo » Thu Feb 08, 2018 10:37 am
Maybe you have accidentally removed the lightbox source folder from your computer?
Normally the 'lightbox' folder is a sub folder of the program files.
barryrodgers
Re: Lightbox Issue
Post by barryrodgers » Thu Feb 08, 2018 11:43 am
Nope. That is there: https://cl.ly/0i173j2X350T
barryrodgers
Re: Lightbox Issue
Post by barryrodgers » Thu Feb 08, 2018 11:49 am
Here is the WYSIWYG 12 project file: https://cl.ly/3c3F2o0d3K1x
Re: Lightbox Issue
Post by Pablo » Thu Feb 08, 2018 12:04 pm
Thanks for sharing your project. That makes helping you a lot easier (and faster).
You have enable 'do not publish asset' for the object.
So that means that all files belonging to that object will not be published!
barryrodgers
Re: Lightbox Issue
Post by barryrodgers » Thu Feb 08, 2018 12:17 pm
No, Pablo...Thank you for the quick and excellent support.
All sorted. No idea why that was checked or - even worse - why I didn't spot it.
Thanks again!
barryrodgers
Re: Lightbox Issue
Post by barryrodgers » Thu Feb 08, 2018 5:14 pm
One more question on the lightbox....
Is it possible to edit the dimensions of the lightbox?
Barry
Re: Lightbox Issue
Post by Pablo » Thu Feb 08, 2018 6:01 pm
This is documented in the help.
nerdtech
Re: Lightbox Issue
Post by nerdtech » Thu Feb 08, 2018 6:01 pm
Forgive me if I am wrong on this but when you select to open something in a lightbox you can click on the "Settings" button. That opens a dialog box where you can, among other things, change the dimensions of the lightbox by entering something like this:
width: 650,
height: 500
There are also some other things you can alter, see the lightbox API: http://fancybox.net/api
thanks.
