Unnecessary quote sign after custom attribute for the <A> tag
sergwerk
Post by sergwerk » Tue Apr 24, 2018 2:38 pm
By adding the <download> custom attribute for the <A> ancor tag ("Edit Hyperlink" menu),
WYSIWYG 12.5.1 inserts after this attribute one quote (") sign.
HTML gets no <download>, but <download"> record.
<a href="images/01.jpg" download">File download</a>
Any idea why?
Re: Unnecessary quote sign after custom attribute for the <A> tag
Post by Pablo » Tue Apr 24, 2018 2:53 pm
Added attributes must be quoted: name="value" (see instructions). So, 'download' is not supported.
sergwerk
Post by sergwerk » Tue Apr 24, 2018 3:00 pm
The value of attributes must be quoted, but not attributes himself (see instructions).
<download> attribute has no values.
All the attributes without values are not supported or the <download> only?
Thanks.
Post by BaconFries » Tue Apr 24, 2018 3:18 pm
The attribute must be written as such download="yourimage" not download or download" Also note that download=" " is a feature of HTML5 so the Doctype of page must be set to this.
Incorrect ❌
Correct ✔
<a href="images/01.jpg" download="myimage">File download</a>
sergwerk
Post by sergwerk » Tue Apr 24, 2018 3:37 pm
The both are correct actually.
Syntax the download attribute is: <a download="filename">
Value <filename> is optional.
This specifies the new filename (if you wish the new one) for the downloaded file.
But is not one must.
If the value is omitted, the original filename is used.
https://www.w3schools.com/tags/att_a_download.asp
Post by Pablo » Tue Apr 24, 2018 3:44 pm
I was referring to custom attribute section of the text. It only supports attributes with values.
This is related to the way the text editor (MS) works internally, you cannot use single words. Attributes must be in the format: name="value"
What you can try is to use download="" (empty value)
sergwerk
Post by sergwerk » Tue Apr 24, 2018 3:58 pm
Oh, I see.
Provisionally being it is an acceptable solution.
I'm curious how various browsers will react to the trick.
Also in the future.
Worst case is the rare construction <= ""> easy to fish out of the HTML by hand.
Thanks for the rapid help!
