scrool "jumps"
semua
scrool "jumps"
Post by semua » Tue Jun 05, 2018 3:36 pm
Hello
I'm having problems on page with "hide/show" events on objects. By moving the scrool up or down it "jumps". Please move the scrool on the link desktop: https://bit.ly/2syuKxj
This problem did not seem to exist in the previous version of the software, so I did not change anything, just version.
Re: scrool "jumps"
Post by Pablo » Tue Jun 05, 2018 5:10 pm
What do you mean by 'jump'?
Where exactly on the page do I need to look?
semua
Re: scrool "jumps"
Post by semua » Tue Jun 05, 2018 7:44 pm
Looks at the gif, on the scroll bar when I move it:
Re: scrool "jumps"
Post by Pablo » Tue Jun 05, 2018 8:31 pm
This is most likely caused by the scroll animation which affect the page length and therefor update the scrollbar size.
semua
Re: scrool "jumps"
Post by semua » Tue Jun 05, 2018 9:43 pm
This is happening on every page that has animation. How do I resolve this without removing the animations? Follow part of the project if you can help me. https://bit.ly/2JniHcF
Re: scrool "jumps"
Post by Pablo » Wed Jun 06, 2018 5:55 am
I think you will need to select a different type of animation that does not affect the page size.
Note that this has nothing to do with WWB. If an animation affects the page size then this is expected behavior.
semua
Re: scrool "jumps"
Post by semua » Thu Jun 07, 2018 1:38 pm
Okay, I'll try to solve it, thank you!
