Hamburger animations
bayernalbert
Post by bayernalbert » Wed Jun 06, 2018 4:38 pm
Are hamburger animations only possible by using the panel menu or is there a possibility to implemnet hamburger animations in other navigation menus?
Would be great, if the animations could be used with icons and a selfbuilt menu.
Re: Hamburger animations
Post by Pablo » Wed Jun 06, 2018 4:56 pm
The hamburger animations are currently only available for the Panel Menu.
It will be difficult to apply them to other menus because you will need to keep track of the state of the menu.
