Issue with the Panel menu
antony
Post by antony » Fri Jul 06, 2018 10:52 pm
Hello, I experience a strange behaviour when using the Panel menu and other navigations of that sort. When I place a Panel Menu object inside a folder (directory under the home directory. EXAMPLE: PUBLIC_HTML > ARTIST), they just don't work. Here is an example- https://antonydesigns.net/demo/wwb-issu ... alone.html. This issue only seems to appear in WWB14, because when I open older projects that include the panel menu on pages that are placed in sub-directories, they just don't work. Regards.
Re: Issue with the Panel menu
Post by Pablo » Sat Jul 07, 2018 6:54 am
Did you use master pages/frames?
In that case the master page with the menu should be in the same folder as the other pages. This is documented in the help.
antony
Post by antony » Sat Jul 07, 2018 7:40 am
Hello, I haven't used any master pages in this particular document. This menu just does not work when I place it on pages that are under sub-directory. I experience this only in WWB14. I recorded a video demonstration here- http://antony.ga/files/wwb-issue.mp4
Post by Pablo » Sat Jul 07, 2018 10:26 am
I think the problem is unrelated to the panel menu.
The browser displays an error related to the search index. The search database is missing on the server: searchindex.js,
Please make sure that you publish all files.
antony
Post by antony » Sat Jul 07, 2018 7:13 pm
I checked it and it actually worked. Thank you, Pablo!
