Navigation Bar
keving
Navigation Bar
Post by keving » Sat Aug 11, 2018 6:23 am
Have problems with Navigation Bar on Edge, OK on Chrome, single line horizontal menu become vertical with duplicated entries on edge when I copy menu from one page to another. Have picture but cannot see how to attach
Kevin
Re: Navigation Bar
Post by Pablo » Sat Aug 11, 2018 6:52 am
Maybe you have added conflicting code to the page?
What exactly did you do?
keving
Re: Navigation Bar
Post by keving » Sat Aug 11, 2018 7:25 am
Have one page with menu working fine, first problem occurred when I copied to three other pages on same site Ctrl C and Ctrl V, first two no problems, third, OK preview, but 4 horizontal menu turned into a 4 item vertical menu with horizonal single horizontal duplicate appearing next to each when uploaded
Have a look at test I just uploaded to http://www.kevinandanneguest.com/2018/mccruise/test.php
Copied from this page that works http://www.kevinandanneguest.com/2018/m ... bourne.php
OK in Chrome but no good in Windows 10 Edge.
Note seemed to copy more than once to cause error, first copy at top OK
Thanks for your help
Kevin
Re: Navigation Bar
Post by Pablo » Sat Aug 11, 2018 11:15 am
It seems to work OK for me. I do not see any errors.
Maybe there is something wrong with your browser?
keving
Re: Navigation Bar
Post by keving » Sat Aug 11, 2018 8:58 pm
one fast update loop for windows 10
Microsoft Edge 44.17733.1000.0
Microsoft EdgeHTML 18.17733
Kevin
keving
Re: Navigation Bar
Post by keving » Sun Aug 12, 2018 2:39 am
Windows update overnight, seems to have fixed problem, also have put one menu on the master and embedded it.
Thanks again for you quick and helpful advice
Kevin
