sub menu is under page content - help
longman
Post by longman » Wed Dec 12, 2018 11:08 am
Hello,
The sub-menus of the navigation menu (CSS Menu) goes under the content of the page, i wonder why and how to solve it?
screenshot of the problem https://cdn1.imggmi.com/uploads/2018/12 ... 2-full.png
Thanks!
Re: sub menu is under page content - help
Post by Pablo » Wed Dec 12, 2018 11:18 am
Did you make sure the z-order is above the other elements (arrange->move to front)?
longman
Post by longman » Wed Dec 12, 2018 11:39 am
Hello Pablo,
The menu is within the Master page.
How do I make Master page's z-order above the elements within another page?
Post by Pablo » Wed Dec 12, 2018 12:26 pm
The elements of a master page will always be at the background otherwise you cannot place other objects on top of it.
Note that normally a dropdown menu is part of a page header. In that case you can set the stack order to 'in front of content'.
longman
Post by longman » Wed Dec 12, 2018 1:27 pm
Where are "Stack order" and "In front of content" options?
I have upload an example https://ufile.io/uibsh in which sub menu goes under the content of the page.
longman
Post by longman » Wed Dec 12, 2018 1:34 pm
PS - in my previous web design software, we could add this code within the html of the panel/menu:
z-index:100;
It would make the menu to be always on top of other elements on the page, even if the menu was within the masterpage.
Possible to do it here?
Post by Pablo » Wed Dec 12, 2018 2:50 pm
The menu is not on a page header.
- insert a page header
- set the stack level to 'in front of content'
- add the menu to the page header
You can add custom code via Page HTML or an HTML object.
longman
Post by longman » Wed Dec 12, 2018 3:21 pm
added the code in menu HTML and worked :)
Another question, since its related to the same sub-menu, i'll ask it here.
my sub menu width is 320, displays nicely in desktop.
However, I have a mobile version too, it goes to mobile at 768 breakpoint, and when in that breakpoint I rollover the mouse on the menu, the sub-menu is 320, it does not fit the screen (below 768).
Is it possible to make the sub-menu to fit the screen size automatically?
Post by Pablo » Wed Dec 12, 2018 6:28 pm
No, I think it's better to use one of the responsive menus for that.
44MLB
Post by 44MLB » Tue Feb 26, 2019 7:01 am
Hi longman
I have a similar problem with icons, maps etc. going over the top of a responsive menu.
Any tips on were and how to enter the "z-index:100;" ? It would be nice if this fixed the problem.
Post by Pablo » Tue Feb 26, 2019 7:15 am
44MLB
Post by 44MLB » Tue Feb 26, 2019 8:37 am
I have the responsive menu in a layout grid on a master page.
Post by Pablo » Tue Feb 26, 2019 9:06 am
Normally a dropdown menu is part of a page header. In that case you can set the stack order to 'in front of content'.
With layout grids there is no z-order, all elements will be floating after each other. See the previously comments of this discussion.
44MLB
Post by 44MLB » Tue Feb 26, 2019 3:29 pm
Unfortunately I can't get the design I want to work in a header.
Post by Pablo » Tue Feb 26, 2019 4:10 pm
In that case you will have to add the z-index yourself.
