Why different synchronise levels?
sommerpierre
Post by sommerpierre » Sat Jan 26, 2019 11:59 am
Hello, I have just a question for understanding the options in the properties of the „css menu“.
There, under the option „Synchronise with the site manager“ are four possible choices for „Sync with“: First Level - Parent Level - Current Level - Child Level.
Can you explain what exactly this mean? In the help I didn't find any explanation to that.
Gruß
Sommerpierre
Re: Why different synchronise levels?
Post by Pablo » Sat Jan 26, 2019 12:03 pm
The options are documented in the help:
First Level
Creates buttons that will link to the children of the root level.
Parent Level
Creates buttons that will link to all pages in the level above the current page in the Site Manager.
Current Level
Creates buttons that will link to the current page and all other pages that share the same parent page.
Child Level
Create buttons that will link to the children of the current page.
sommerpierre
Post by sommerpierre » Sat Jan 26, 2019 5:27 pm
Perhaps my intellect is not sufficient to understand this terms. Will this say (see image):
1 = Root Level
2 = Parent Level
3 = Child Level
All this four Levels create buttons but the links of these buttons are different?
„First Level“
If I choose this option the buttons created will link „only“ to the children from the root level, but not to all other pages?
„Parent Level“
If I chose this option the buttons created will linked with all pages above. If my page with the css menu is the last page in the site manager, automatically all pages are synchronised?
„Current Level“
If I choose this option the buttons created will link „only“ with the pages on the same parent page. (Useful only for more then one menu bar?)
„Child Level“
If I choose this option the buttons created will link „only“ with the pages under the current page?
What effects have the four possibilities under „target“ (blank - self - parent - top)?
What are the default options for „Sync with“ and „Target“ if I choose „Synchronise with the Site Manager“?
Gruß
Sommerpierre
Post by Pablo » Sat Jan 26, 2019 6:05 pm
I'm sorry, we cannot view images that are your computer.
If you do not have multiple level sin the Site Manager, then there is no different between the options. They are are useful if you have folders.
That effects have the four possibilities under „target“ (blank - self - parent - top)?
This is standard HTML functionality. The options are also documented in the help.
blank
opens the link in a new window
_self
open the link in the current frame
_parent
open the link in the parent frame
_top
loads the linked document in the topmost frame
dnlyko
Post by dnlyko » Sun Mar 31, 2019 10:12 pm
First Level
Parent Level
Current Level
Child Level
This does not seem to work with the OverlayMenu.
I selected Child Level and it displays those pages in the Items Menu Items above the Synchronize display but when I preview or publish the menu defaults to the root not the child items.
http://mysnapsonline.com/psychedelic.html
This pertains to the grey OverlayMenu in centre of page, not the green OverlayMenu on the masterpage header this page is using
Post by Pablo » Mon Apr 01, 2019 6:14 am
It looks like the menu is on a master page/frame?
In that case the synchronizing is relative to the master.
