Responsive menu - reducing the spacing between menu items
Within a responsive menu, is it possible to reduce the spacing between the selected menu items, thereby making the menu shorter?
- crispy68
Re: Responsive menu - reducing the spacing between menu items
open up the settings, go to style tab and under Main Menu change the padding left/right settings.
Tried this already. Makes no difference except in the default view. On the different viewpoints, it makes no difference.
- crispy68
If you are referring to when the menu flips to vertical, then try adjusting the padding top/bottom values under 'sub menu'
Hey, thanks a LOT! It now works like a charm.
