Scrollspy, Affix and PAID for animated menu
FX3D
Post by FX3D » Mon Apr 15, 2019 7:27 pm
Hi Pablo can you enable scrollspy & affix options in the "Style" options (PAID version of Animated Line Menu), or maybe tell me how to achieve this
I want to use the Line menu I bought but keep it affixed at the top as per your tutorial Here: http://www.wysiwygwebbuilder.com/affix_ ... llspy.html
Many Thanks
Re: Scrollspy, Affix and PAID for animated menu
Post by Pablo » Mon Apr 15, 2019 7:56 pm
Did you consider adding the menu to a sticky layer?
FX3D
Post by FX3D » Mon Apr 15, 2019 8:19 pm
Hi, thanks for the fast reply, I was actually doing this just now and managed to eliminate the "bounce" from sticky layers adjusting the duration
Great support
Thanks Again
