Menu is shown behind a picture
Erik88
Post by Erik88 » Mon May 20, 2019 6:26 pm
I use a Responsible Menu in a Flexgrid.
Below the menu is a picture. When the menu is pulled out it is shown behind the photo.
Any workaround?
Re: Menu is shown behind a picture
Post by Pablo » Mon May 20, 2019 6:30 pm
In a floating/flexible layout, objects do not have a z-index. So, the objects that come after the menu will be render on top.
Note that normally a drop down menu is part of a page header, in which case you can configure it to 'in front of content'
Erik88
Post by Erik88 » Mon May 20, 2019 7:28 pm
Thank you Pablo.
Strange thing is, The photo is part of a Flexgrid. Above the photo is a text object, also part of the Flexgrid. The text is shown below the menu.
Post by Pablo » Mon May 20, 2019 8:21 pm
To be able to help you I need to see what you have done (project flle)
However, I am pretty sure it's related to the order of the objects.
As you can see in most templates, the menu is usually on a page header so you can control the order.
