OverlayMenu
MartinPorter
OverlayMenu
Post by MartinPorter » Thu Jun 13, 2019 8:16 pm
Hi all..
Can someone tell me how many pages and sub pages can you have in a OverlayMenu ?
Thanks & regards
Martin....
Re: OverlayMenu
Post by Pablo » Thu Jun 13, 2019 8:26 pm
There are no known limitations other than the available screen space.
MartinPorter
Re: OverlayMenu
Post by MartinPorter » Fri Jun 14, 2019 10:41 am
Hi Pablo, would your Bootstrap Meag Menu sort my problem out? - my site could grow to over 200 pages and will need the user to scroll down a list? - btw off the subject, but is your hosting ok I keep timing out?
Thanks & regards
Martin....
Re: OverlayMenu
Post by Pablo » Fri Jun 14, 2019 11:27 am
I think, you should pick the menu that works best for you.
Although, I think 200 links is a lot, no matter which menu you choose.
I'm sure they are working hard to fix this as soon as possible.
MartinPorter
Re: OverlayMenu
Post by MartinPorter » Fri Jun 14, 2019 11:41 am
thanks Pablo.. Don't I know-it :shock: the project was set up for just a small group, now everyone wants to jump on board
the hosting looks fixed from here.
Thanks & regards
Martin....
