*** SOLVED *** page layout problem
eozl
Post by eozl » Sun Nov 29, 2015 9:49 pm
http://www.megep-modulleri.com/4.08-467 ... -giris.php
In this link , something seems wrong I can't find.
There are so many pages with same page properties but only content different. Other pages look OK.
(For example: http://www.megep-modulleri.com/1-ambulanslar.php)
What can be possible causes for this failure?
Thanks in advance.
Re: page layout problem
Post by Pablo » Mon Nov 30, 2015 9:20 am
The IDs of some of your objects are invalid.
The ID should not start with a number.
Related FAQ:
http://wysiwygwebbuilder.com/forum/view ... 10&t=64868
eozl
Post by eozl » Mon Nov 30, 2015 11:21 am
Pablo wrote:The IDs of some of your objects are invalid.
Related FAQ:
Thank you pablo for reply.
I did what have you had said but unfortunately nothing changed. What's more all images consisting pages that working properly (I mean already made before) have the same id system (which starts with number) and layout seems OK in browser.
What I am confused, I clone a working page , I change related subjects (content, some page properties etc.) as I did always, but for some pages (which is mentioned and linked aboved topic), image seems badly.
Post by Pablo » Mon Nov 30, 2015 2:53 pm
I'm sure the issue is related to your invalid IDs.
For example: '4.08-467-hastalik-ve-ilaclara-giris' is NOT valid.
Please fix them all.
eozl
Post by eozl » Mon Nov 30, 2015 4:29 pm
Pablo wrote:I'm sure the issue is related to your invalid IDs.
After changing ID's of images in pages (by starting with letter instead of number) , problem is solved.
Thank you pablo.
